Heat and A/C stopped working after oil pan swap
Old Jul 9, 2013 | 10:01 AM
FirebirdJim94's Avatar
Car: 1991 firebird base/ 1985 Trans Am
Engine: 91: 3.1 T/A: 350
Transmission: 700r-4
Axle/Gears: 91: 3.23 T/A: ?
Ok, so I recently swapped the oil pan for a new one in my 1991 Firebird 3.1. When I did so I noticed a week later that my heat stopped working. I also noticed that my A/C isn't working.
For the Oil pan change I unbolted everything from the motor (Trans, Motor mounts, starter, etc.) and unbolted the pan from there. I put the new pan in and lowered the motor back onto the mounts and bolted everything up.
So, to get to the point. I turn on the heat and I can hear it engage and try to blow but nothing. Same with the A/C. I'm thinking something got pulled off, disconnected, or kinked up somewhere along the motor being lifted up 3-4 inches to replace the pan.
Any help would be highly appreciated since I can not see anything through my windshield without defrosters. Thanks in advance, Jim.
Old Jul 9, 2013 | 01:35 PM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Re: Heat and A/C stopped working after oil pan swap
LOL.
check the wiring at the blower motor assembly.
Old Jul 9, 2013 | 08:12 PM
alright man i'll give it all a look this weekend. Will let you know lol.
B_Dubya
Aug 26, 2015 05:09 PM
MY87LT
Aug 17, 2015 08:43 AM
matthew911
Aug 12, 2015 09:38 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
gwade12
Aug 8, 2015 08:17 AM
