91 camaro wont start?
Old Jul 10, 2013 | 11:45 PM
DirtySpleen's Avatar
Car: 1991 Camaro RS
Engine: 5.0 L03
Axle/Gears: 3.43 Torsen 10 bolt
so while I was in the parking lot at autozone, whenever I tried to start my car up again, the fuel pump did not prime, and because of this, the engine turned over, but refused to start. This happened once previously about a week ago, but to fix it I just messed with the relay, and the car fired back up. This time on the other hand, I was at autozone like I said, and thinking that it might be a bad relay, I went ahead and bought a brand new one. I installed this new relay, and found that this wasn't the culprit. next, I checked the fuse for the fuel pump, and decided to go ahead and replace it even though it was not burnt out, just to make sure that it wasn't warn from age.once again, I did this to no avail. I was completely out of ideas as to what could be wrong, so I just walked over to the gas station and got a gallon of fuel. I poured a little bit of the fuel into the carburetor just to see if it would fire. To my surprise, the engine fired right up, and shockingly did not die like I thought it would after a few minutes. After looking, the injectors were pumping fuel into the carburetor and the car was running normally, but with a high idle. Does anyone has any idea what could possibly be wrong with my car, As I am completely out of ideas. From how I see it, the car would have died shortly after I fired it up if the fuel pump was burnt out. Seeing as I was able to drive home and it never cut out, the fuel pump has to still be working, right? My car is a 305 tbi camaro rs with 5 speed.
Old Jul 12, 2013 | 02:20 PM
ParkerTPIz's Avatar
Re: 91 camaro wont start?
Sometimes they completely go out and sometimes they gradually do.
If you checked the fuse & relay, and they were both good then more than likely you need to replace it. When you do, replace the stock filter as well.
How many miles are on it, and have you ever replaced it in the past?
Old Jul 15, 2013 | 06:38 PM
Car: 1991 Camaro RS
Engine: 5.0 L03
The car is new to me, so I havent replaced it. 174K miles. Im curious, should I hear the relay click atleast if the fuel pump isnt working, I dont hear the click or prime... (trying to eliminate everything before having to drop the tank, Id have to get it towed in order to do that so id like to avoid all that hassle if at all possible)
Old Jul 15, 2013 | 06:49 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
You may have an intermittent short in the wiring as well, I would check for corrosion at the terminals and for signs of a broken or grounding wire.
Old Jul 15, 2013 | 07:36 PM
Car: 1991 Camaro RS
Engine: 5.0 L03
Where along the wiring would i look? Theres a lot of wiring and im not sure where all it runs.
Old Jul 17, 2013 | 12:47 PM
smittyakalance's Avatar
Car: 1991 Z28
Engine: 383 Stroker with edelbrock heads
Axle/Gears: 4.10 Posi
put gas down the tbi or carb and see if it will run fore feeding if it does you for sure have fuel problems
Old Jul 17, 2013 | 04:32 PM
Car: 1991 Camaro RS
Engine: 5.0 L03
It is a fuel issue. The relay isnt clicking and the pump isnt priming. Fuses and relays are good.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Caspar
Jun 19, 2016 11:19 PM
92camaroJoe
Aug 13, 2015 06:07 AM
