In Tank Fuel Pump
Old Jul 12, 2013 | 12:03 PM
dmwracing42's Avatar
Car: 1984 Trans Am
Engine: 355
Axle/Gears: 10 Bolt, Torsen Diff, 3.73's
In Tank Fuel Pump
I have a carbed '84 T/A. VIN says it's H.O., and I'm doing a 350 swap. Question is, do I have an intank fuel pump?
If I do, when I drop the tank what am I replacing the in tank pump with?
Old Jul 12, 2013 | 12:07 PM
3rdgenlewis's Avatar
Car: 89' RS.
Engine: Carbureted 305.
Transmission: Built 700R4.
Axle/Gears: 4.56
Re: In Tank Fuel Pump
Curious as too why you'd drop the tank? Lay your rear seats down, remove the carpeting and cut out the sheet metal over the tank, that's what I did.. way easier.
Old Jul 12, 2013 | 01:21 PM
Car: 1984 Trans Am
Engine: 355
Well included in my engine swap is the rear end and full exhaust. From reading on here, once the rear end is down, the gas tank isn't too hard to drop, and I'd prefer not to cut a hole if I can avoid it.
But, since you've done this, did you just run a line to the gas tank or did you get a pickup out of another car?
Grant2k
Jul 10, 2018 04:01 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
Kaweh
Aug 9, 2015 02:54 PM
