86 TPI hot start problem
Hey guys,86 5.0 tpi, stock.Starts great cold and pretty good after sitting a short time after driving.The other day,hot outside,drove great for a hour then sat for about 3 hours and did not want to start.When it did the idle was slow and rough had to brake and pedal to get it going then pushed it to clear it out.It has done this before at times.Recently new plugs,wires,coil,cap,02 sensor...fuel pressure good when checking it for initial psi.I have read that the original injectors tend to leak down basically flooding the car.It still has the originals at 156,000 miles.Was going to change the temp sensors out but didn't.Ideas Maf sensor,coolant sensors,Iac,injectors any help appreciated.Thanks Allan
Re: 86 TPI hot start problem
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Sanjay
Aug 12, 2015 03:41 PM
db057
Aug 11, 2015 10:11 PM
