vibration at high speed
Old Jul 18, 2013 | 10:26 AM
kbish's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 V8
Transmission: Automatic
Hey guys, I have a 1988 firebird with the 305 tbi engine. Mostly stock with an open element that I installed last week. I have recently noticed a vibration when I get up to about 80-85 mph.
I am about to install my new y pipe, cat, and cat back. Just wondering what I should be looking for while im down there.
Kevin
Old Jul 18, 2013 | 10:33 AM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Re: vibration at high speed
The stock driveshaft... is poorly balanced and you will experience high speed vibrations until you replace it with a better unit...
Inland Empire makes a direct fit aluminum piece.. I forget if it came with new u-joints but it will solve the problem.
The difference is immediate... I did that in 2003 then had it shortened in 2005 when I did the 9" rear.
I parted with it last year when I switched from the 700R4 to a Turbo400..
Old Jul 19, 2013 | 12:47 PM
kbish's Avatar
Engine: 305 V8
Okay, so nothing too serious then. I just needed to make sure it wasn't gonna fall apart when I hit 88 mph hahaha
Thank you
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
