Need 2 Replacement valves for dart iron eagle head. Anybody know where?
Old Jul 18, 2013 | 06:51 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
I might be getting a set of Dart iron eagle cylinder heads from a friend pretty cheap. Only problem is there are 2 missing valves on one cylinder. Apparently he had them in being checked and the machine shop lost them. It's a long story but the heads are practically new so I was hoping to just get 2 replacement valves.
So I'm wondering if Dart has replacement valves or does it matter if they are original valves. I looked on their website but I didn't see any..
Any help would be appreciated.
Old Jul 18, 2013 | 07:38 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Need 2 Replacement valves for dart iron eagle head. Anybody know where?
Only certain sizes of valves used in SBC heads so any parts shop should have them once you know what size
you are looking for ( or take one in with you )
FWIW;
They are SBC heads made by DART to replace SBC heads so they take stock sized components
Old Jul 18, 2013 | 09:28 PM
Depends on the heads...
They didn't use stock GM components in them. You shouldn't either.
Doesn't too much matter that the ones you replace them with are "identical", so long as the dimensions are the same. (length, stem undercut, tulip shape, etc.)
Pick up the phone and call em. They've always been pretty helpful when I had a question about their product.
Meanwhile, an important question you should ask yourself is, if your friend is selling them "cheap", why? What does he know that you are yet to find out? How did a formerly (I assume) useful set of heads, come to be in the condition they are currently in?
sailtexas186548
Jan 19, 2016 12:21 PM
gta90
Sep 15, 2015 04:00 PM
NBrehm
Aug 25, 2015 11:49 PM
InfinityShade
Aug 22, 2015 08:00 PM
