L69 Engine Vacuum Question
Old Jul 20, 2013 | 10:36 PM
jraider66's Avatar
Car: Customized 1982 z28
Engine: L98 350
Axle/Gears: 3.23 10 bolt Limited Slip
I was wondering what kind of readings I should be getting for vacuum on an L69? I am currently getting around 13-15. I think that is low. What should I be shooting for?
Old Jul 21, 2013 | 08:26 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: L69 Engine Vacuum Question
It should be 18-19, depending on elevation.
If the cam has been changed, then that will affect it.
15 shouldn't cause any real problems.
Old Jul 21, 2013 | 12:54 PM
jraider66's Avatar
Engine: L98 350
I was out messing with the engine today and have a steady 16. I am concerned that I might have a worn out cam or something of that sort. It wouldn't be the end of the world. I wish someone knew whether an L69 should be pulling 20 or above. Messing with the timing does not change the reading much. Maybe a degree.
Old Jul 21, 2013 | 01:29 PM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
I've seen a more aggressively-cammed 305 pull 16", but if you were losing a lobe or 2 your vacuum reading would fluctuate and your idle would sound wrong. Have you checked for vacuum leaks from the intake gaskets?
Old Jul 21, 2013 | 02:52 PM
jraider66's Avatar
Engine: L98 350
I was using a scope the other day and I had cylinders dropping out on the driver's side bank. I poured water on the intake on that side and the cylinders seemed to stop dropping out. I wasn't sure enough with the results to declare it an intake leak, but you may be right on the money. How much of a fluctuation would you see if a cam was going out? Would it be really noticeable? Like a degree or more? Or just tiny fluctuations? Thanks for your input.
84z96L31vortec
Aug 20, 2017 12:16 AM
theshackle
Mar 5, 2017 06:37 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
