need some help 88 gta
Old Jul 25, 2013 | 08:03 AM
rosey88gta's Avatar
Car: 1988 gta
Engine: 350 tpi
Axle/Gears: 3:23 posi
first off hello everyone this is my first post i just recently bought an 88 gta trans am while im deployed to kuwait for the army. It has a holley stealthram 27 psi injectors, vortec heads ground for a lunati 503 roller cam and flat top pistons. my brother said it has gobbs of power but runs slightly rich and the tach doesnt work because the stealth ram needed a different distributor so they didnt know how to run the wiring to the msd ignition. Im going home in a few weeks and would be looking for some insight as to what may be wrong with it. I got the car for a steal and am willing to put some money into it to make it run like it should. Any starting ideas would be appreciated. Thank you
Old Jul 25, 2013 | 09:52 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: need some help 88 gta
I'm not sure why the HSR would require a different distributor. The 88 already comes with the small-cap distributor and should have no issues with the HSR other than finding a place to mount the remote coil.
As for running rich, it could be a number of things. Does the car have a custom tune or is it still running on the stock tune? In either case, it could be a matter of making sure the tune has the right injector constant and correct fuel tables, or you could have some sort of other problem such as a stuck injector, bad O2 sensor, bad temp sensor, etc.
F-body-fan
Jan 12, 2023 01:49 PM
sheachopper
Jul 31, 2019 11:27 AM
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
