Is there an aftermarket temp gauge that will work on the stock sensor?
Old Jul 28, 2013 | 11:47 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
My temp gauge was fine. I cranked the car and it spiked during cranking which is normal. It just never came back down and is stuck. I tapped the gauge and it fell back down. I put key forwarded. Was still fine. I cranked car and the same thing happened and it stuck maxed out. From what I've read here. If the sending unit is bad, or the wire is grounded. It will cause it to stay spiked. But since it went back down and I put the key forward and it still was fine. Tells me that the sending unit and wiring is ok. It just seems to get stuck when cranking.
Anyway. Do all these aftermarket gauges have to run off there own sending units? If so, is there one that will fit where the stock sending unit is now?
Ghettobird52
Jul 5, 2024 11:18 PM
Reddeath210
Oct 6, 2015 08:20 AM
Wade787b
Sep 29, 2015 01:15 PM
justin57
Aug 20, 2015 07:05 PM
Irocohio
Aug 12, 2015 08:03 AM
