Help with manifold sensors.
Old Jul 30, 2013 | 05:06 PM
87irocZ28Crush's Avatar
Car: 1987 Iroc Z28
Can you please tell me what sensors go in these holes from top to bottom, left to right? Also the small hole in the block above the timing chain cover? I bought the car with a fresh rebuild on the 305 and had to put the top half of the motor together. Thanks for the help.
Old Jul 30, 2013 | 05:10 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Help with manifold sensors.
On the left bottom, Bosch csi timer switch, Bypass coolant fitting above it cts.
Old Aug 5, 2013 | 02:08 PM
Car: 1987 Iroc Z28
Coolant bypass on bottom right
Coolant temp sensor on top right
Csi switch? What is this? I tried google and came up with nothing.
Thanks for the help
Old Aug 5, 2013 | 02:15 PM
Engine: Lb9
Transmission: M20
http://www.ecklerscorvette.com/corve...1985-1988.html
You can buy a cold start block off kit from ebay and use a npt plug to block the hole and goto 89 programing as well. if thats a route you want to take send me a pm I do reprograming
http://www.ebay.com/itm/Camaro-Firebird-TPI-Cold-Start-9th-Injector-Block-Off-Delete-Kit-/290947565358?pt=Motors_Car_Truck_Parts_Accessories&hash=item43bdd3872e&vxp=mtr
Old Aug 5, 2013 | 02:19 PM
Car: 1987 Iroc Z28
Camaro Firebird TPI Cold Start 9th Injector Block Off Delete Kit | eBay
Cold start injection switch. Was just reading it lol. I will be sending you a pm here soon. I'm getting rid of the smog and egr crap on my motor and will need some reprogramming. I'm still in the process of putting everything back together. I wanted to go with all new sensors and what not. The motor is out and fresh rebuild so why not do it all new.
Thanks for your help.
db057
Jan 10, 2020 08:55 PM
sailtexas186548
Feb 17, 2017 03:07 PM
Chas91Z28
Oct 22, 2015 10:12 AM
86CamaroDan
Sep 29, 2015 10:08 PM
