lunati 60102 cam help
Old Aug 2, 2013 | 07:27 AM
Zach92305's Avatar
Swapping a lunati cam into my 1992 305. The stock 305 cam has a lip on it allowing the cam guard to fit over the end but the lunati cam does does not have this lip. What steps do i need to take to fix this issue?
Old Aug 2, 2013 | 10:56 AM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Re: lunati 60102 cam help
Is it a roller cam? Ur engine uses a roller cam. I'm not at a desktop so I can't look it up but I'm pretty sure that's the can I use in my non roller block. Make sure its right for Ur application.
Old Aug 2, 2013 | 11:27 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
There should be a dowel pin that comes with the cam that you can use in place of the "lip".
Old Aug 2, 2013 | 10:03 PM
Chad85T/A's Avatar
Car: 85 T/A
You'll have to change the timing chain from a roller style chain to a flat tappet chain and you'll need longer push rods.
Old Aug 2, 2013 | 10:07 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Lip is for the retainer plate. Called a stepped nose. 87-99 type blocks that came with oem rollers. If you cant send cam back you may need a regular sbc timing chain as mentioned and a thrust button on the timing cover to keep cam from walking. Basically how all other sbc's are
Old Aug 2, 2013 | 11:41 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Why are you fitting a flat tappet cam to a roller block setup?
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
john204481
Sep 7, 2015 03:22 PM
