Is TDC at the 0 mark on the balancer?
Old Aug 5, 2013 | 12:40 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
I am dumb and forgot to set up TDC on my new motor before dropping in the distributor. Because of my procharger and long tubes, I cannot access cylinder #1 spark plug very easily at all and my procharger body rests right on the top corner of the valve cover so removing it is out of the question.
Can I turn the balancer to 0 degrees and set the distributor to firing on cyl #1? and if it does not sound right can I flip the distributor 180?
Also I was considering removing the passenger valve cover and watching the valves move, wait for cyl #2 to move and then carefully assume where #1 would be?
Old Aug 5, 2013 | 12:52 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Is TDC at the 0 mark on the balancer?
That *should* be the mark. You could pull the pass. side. valve cover, find TDC on #6 w/the valves open which would put #1 at TDC w/the valves closed. Drop the dizzy in, slap on the plug wires, (in the correct order, of course!), and you should be golden.
Old Aug 5, 2013 | 12:56 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Oh yes I was wondering about that, what would be a hint to when cyl #1 is at TDC, so when both valves are open on Cyl#6 (during overlap) is when cyl #1 should be damn near TDC and my balancer should also be approaching near 0 degrees? I just got a new TCI Rattler installed and it has real nice timing notches.
Old Aug 5, 2013 | 03:53 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Just a follow up that my car is running now. I did what watajob recommended and it worked perfect.
Old Aug 6, 2013 | 06:41 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Good tip!
apie2546
Oct 16, 2016 02:24 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
gord327
Oct 3, 2015 01:25 PM
monte87cortez
Sep 26, 2015 08:10 PM
