Power steering pump still screeches.....?
Old Aug 6, 2013 | 08:52 PM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
So my old pump had gone bad it was leaking a lot and made very loud screeches when turning now that I installed a new pump with the housing, it doesn leak but still screeches not as much but still does...Anyone know what might cause this or did I just happen to pick up a defective one from Autozone..??
Old Aug 8, 2013 | 04:49 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
A little more detail required.
Screeches when? All the time? When turning? At the turn lock?
Did you replace the belt when you replaced the pump?
Are you sure you have the belt tight enough?
Are all the mount/adjustment bolts installed and tight?
Glowsock
Jul 24, 2025 03:15 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
86White_T/A305
Aug 17, 2015 12:16 AM
