O2 Sensor life expectancy
Old Aug 11, 2013 | 01:28 AM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
I have a 3 wire heated O2 sensor in the driver side header of my carbed 350. It has been there for a few years unhooked plugging the hole.
I am swapping TPI back on the car and was wondering if I cleaned the carbon off the tip if it would be functional again? Any way to test it without the EFI hooked up?
Old Aug 12, 2013 | 04:27 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: O2 Sensor life expectancy
Any idea how old the sensor is? If you're not sure, or it's the original, then go ahead and replace it. IIRC it should be around $30-35, far cheaper than modern cars (not to mention there's just 1 instead of 4).
Old Aug 12, 2013 | 04:37 PM
bwiencek's Avatar
Car: 1984 TA - 17k orig miles
Engine: 355
Axle/Gears: 3.44 Dana 44 performance rear
Test it's output with a VOM while driving - if it works then you're probably good to go - if it's lazy or reads low all the time then take it out - clean it with a hot torch and see if you can revive it - if not do what navy02ws6 said - replace it because it's just plain cheap...
Old Aug 12, 2013 | 04:44 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
While I was at the parts store today I picked one up. $21 for a Denso brand.
gta892000
Aug 11, 2019 11:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
FormulasOnly
Sep 10, 2015 09:07 PM
Eric-86sc
Sep 7, 2015 02:10 PM
