91 RS project..
Old Aug 13, 2013 | 12:13 PM
kevmma's Avatar
Car: 91 Camaro RS 305TBI
Transmission: 7004
Axle/Gears: stock posi .373
91 RS project..
just picked up a 91 rs with a 305... it's DUMPING antifreeze out the exhuast (head gasket) the fan won't switch on, and i'm pretty sure the thermostat is stuck closed.. i know cars, but this is my first camaro.. any tips on getting these first problems out of the way would be greatly appreciated
Old Aug 13, 2013 | 12:31 PM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Re: 91 RS project..
www.rockauto.com
Gaskets & seals
Get a new thermostat (lots on this board use a 170 stat w/ fan switch TS-85 which closes at 211*)
1 fan or 2?
Unplug the fan connector between cylinders 6 & 8. Use alligator clip to ground the wire to the chassis. Fan should engage. If nothing, suspect relay or fan motor.
You also need to be sure coolant hasn't been leaking into the oil. Change your oil for good measure at the same time maintenance is done.
Old Aug 13, 2013 | 01:10 PM
kevmma's Avatar
Transmission: 7004
Re: 91 RS project..
yeah i'm going to switch to synthetic oil anyway.. 1 fan.. i'll try to get that going
Adrian harrison
Brakes
Jan 19, 2013 01:13 AM
BadBilly442
Interior Parts Wanted
Nov 20, 2011 05:57 PM
88MCLS
Exterior Parts for Sale
16
Oct 31, 2011 07:28 PM
383Bandit
Aug 14, 2011 11:10 PM
formula350sd
Apr 6, 2011 03:07 PM
