Adjusted ignition timing and now I have LESS power o.O
Old Aug 15, 2013 | 09:39 PM
XGO MONSTROUS's Avatar
Car: 1988 Camaro
Engine: 2.8 Liter
Transmission: Manual
Hey guys, I don't know if this is normal or not, but here goes:
My engine's ignition timing was set at 16 degrees advanced, and it should be at 10. So I adjusted it to ten a little while ago and now it seems to have LESS power. To me it seems like it should have more. Is there something I'm missing here?
Also, my engine is a 2.8l v6. Thanks for the help!
EDIT: here's some more info: when I was rotating the distributor cap, I had briefly advanced the ignition timing to about 19 degrees and the idle speed seemed to perk up, and when I adjusted it down to 10, the idle speed slowed down. 10 is the recommended place, so this has me pretty confused.
Old Aug 15, 2013 | 10:39 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Adjusted ignition timing and now I have LESS power o.O
Factory tunes are normally rich and retarded from optimum.
Old Aug 15, 2013 | 10:42 PM
Car: 1988 Camaro
Engine: 2.8 Liter
Do you know where optimum is? And would having it there long term damage the engine?
Old Aug 16, 2013 | 05:35 AM
KMdoza7's Avatar
Car: 1989 IROC-Z28 Camaro
Engine: none
Transmission: T-56 W/ Spec 1 Clutch
Axle/Gears: 9 Bolt BW 3.27 Gears
If im not mistaken shouldnt the base timing be at 10*. There is a proper way to adjust the base timing, look it up. On my 2.8 fiero I had to ground the aldl ports so the ecm wouldnt advance the timing and from there I set my base timing at 10*. Not sure about the v6 camaros though.
Old Aug 16, 2013 | 07:19 PM
phonedawgz's Avatar
On your engine you have quick disconnect connector above the heater housing on a Tan/Black EST wire. That connector needs to be disconnected when setting the timing. Setting the timing with it connected results in greatly retarded timing, which generates more exhaust heat (sometimes glowing exhaust manifolds) and greatly reduced performance.
Upper far left on this pic
Remember to reconnect the connector after setting the timing.
Old Aug 17, 2013 | 08:12 AM
Damon's Avatar
Yeah, you've got to set base timing with the timing wire disconnected. 10* is still stock, but on my 91 with the very similar 3.1L V6 I ran it at 14* and it helped a little.
If you're setting the base timing with the timing wire still connected you're going to be WAY retarded from even the stock ignition timing specs in reality.
Old Aug 19, 2013 | 09:51 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
My old V6 was happiest around 12-13, but I had quite a few mods done to it, including 3.4 swap, so youd have to just play around and see what is best.
BRoss99
Aug 10, 2025 05:08 PM
theshackle
Sep 17, 2020 08:26 AM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
