1985 Camaro Berlinetta: Oil pan removal
Old Aug 17, 2013 | 11:39 PM
Tonve's Avatar
I am having hell pulling this oil pan, i've tried lifting the motor, removing exhaust pipes, starter, jacking up the motor several ways, the motor mount bolts are out, i am just at a big loss, and need some help bad. the car is needing to drive asap. doing this on a buddy's car...
Old Aug 18, 2013 | 12:17 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: 1985 Camaro Berlinetta: Oil pan removal
what's the problem? i've never taken an oil pan off on an engine in a third gen F body, but in some cars you can get the clearance you need by turning the crank so that the counterweight of the front crank throw is out of the way..
failing that, it only takes about a half hour from where you are now to unhook everything and just take the motor out of the car..
Old Aug 20, 2013 | 09:58 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
+ 1
Old Aug 20, 2013 | 05:48 PM
Which would be, with the timing mark pointed at about 4:30.
Trying to do an oil pan job that way in one of these cars, is ALOT harder than doing it the RIGHT way. As is nearly always the case, you end up doing more work trying to get out of doing work, than the work you were trying to get out of. In this case, ALOT more work. But you'll know better next time, eh?
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
matthew911
Aug 12, 2015 09:38 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
gwade12
Aug 8, 2015 08:17 AM
