EGR?
Old Aug 18, 2013 | 06:13 PM
72SSboy's Avatar
Car: 1988 IROC-Z
EGR?
Hey there -- I'm guessing the openings under the hood of my 88 IROC are where the EGR set up used to be. I don't feel comfortable with them (there are three pipes) just open sucking in hot dirty air.. what should I cap them off with or attach them to? Thx
Old Aug 18, 2013 | 07:12 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
Re: EGR?
This is the Air Injection Reaction (A.I.R) setup. This is an emissions setup that pushes fresh air to your exhaust manifolds at cold startup and to your catalytic converter at operating temperature.
Old Aug 18, 2013 | 08:04 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: EGR?
Originally Posted by 72SSboy
don't feel comfortable with them just open sucking in hot dirty air.
Look harder; they are on the exhaust manifolds so if they were leaking they would be blowing hot exhaust gas out ; not sucking it in
what should I cap them off with ?
Hardware or plumbing supply shop .
Buy two 1/2" NPT pipe caps like this
Chrome Plated Brass Pipe Fitting, Cap, 1/2" NPT Female: Amazon.com: Industrial & Scientific Chrome Plated Brass Pipe Fitting, Cap, 1/2" NPT Female: Amazon.com: Industrial & Scientific
Unscrew the valves and fit the caps to the thread on the AIR header pipe.
Delete everything else to do with the AIR
Old Aug 18, 2013 | 09:27 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: EGR?
Or 8 or these
http://www.oreillyauto.com/site/c/de...1164&ppt=C0248
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
