oil pressure gauge not working
Old Aug 19, 2013 | 12:30 PM
NotsosleepyZ's Avatar
Car: 89 Firebird
Engine: 5.7
Axle/Gears: unkown
I've put new heads and cam, intake, carb. and all the goodies required. it seems i have oil pressure as it splatters over my intake and headers with the valve covers off, but my oil pressure gauge is pegged at the top of the cluster, the oil pressure switch is new, but my harness is not COMPLETELY hooked up cause i have eliminated the computer. any ideas?
Old Aug 19, 2013 | 02:29 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: oil pressure gauge not working
Does the gauge move when you cut the car on/off? If not, it could be stuck. But the gauge will peg when the wiring is unhooked or a bad sensor. Might want to check the wiring, especially since you said it isnt all hooked up. Find the right wire, if it is unhooked, well hook it up. If it is hooked up ground it and see if the gauge goes to zero. It should.
https://www.thirdgen.org/forums/tech...auge-pegs.html Read Sofa's response. #14
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
ChevyZ71
Aug 13, 2015 07:30 AM
