Need part number for a wire harness connector
Old Aug 21, 2013 | 10:10 PM
IrocRoadRacer's Avatar
Car: 1989 Camaro Iroc Z
Axle/Gears: 9 Bolt Borg Warner/ 2.77 gear
When I was mounting the engine to the transmission, I tightened the mounting bolts without knowing the oil pressure sending unit connector was between the motor and transmission. So the wire is smashed and the connector is stuck where the flexplate is. I am going to snip the wire and let the flexplate crush the connector, then order a new one instead of going through the hassle of taking off all the mounting bolts with all the engine bay components in the way. I am under a time constraint, so I need to know the part number to the oil pressure sending unit connector. I found a part S637, but I'm not sure that's the right part number. Any help would be much appreciated.
Old Aug 22, 2013 | 06:38 AM
Re: Need part number for a wire harness connector
Junkyard
1992 Trans Am
May 10, 2023 07:19 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Reddeath210
Oct 6, 2015 08:20 AM
twest2k2
Aug 24, 2015 11:26 AM
armybyrd
Aug 10, 2015 09:23 PM
