Yea, another "won't start" thread
Old Aug 24, 2013 | 08:27 PM
PaulD's Avatar
Car: 93 9C1 Caprice
Engine: 5.7
Axle/Gears: 3:42
Sorry but I've read the others and the same circumstances don't seem to apply.
I drove my car to work today- first time it's been out in over a month. It drove in just fine. When I went to leave, the car wouldn't start. I popped the hood, pulled off the air cleaner housing and cranked it over. I've got a fuel pressure gauge and it shows pressure is normal- pressure rises when key is turned to 'on' and drops if the car doesn't start within xx seconds. But I notice there's no spray from either injector while cranking, further- both throttle plates are bone dry.
I had the car towed and tucked it back into the garage. Oh, oil pressure gauge at least showed pressure while cranking. I checked all electrical connections.
Good suggestions?
Old Aug 25, 2013 | 01:17 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Yea, another "won't start" thread
Originally Posted by PaulD
notice there's no spray from either injector while cranking, Good suggestions?
Appears to be a lack of injector pulse.
Confirm that by using a noid light.
Do a search on here ,there is a multitude of " no injector pulse' threads with fault finding advice
https://www.thirdgen.org/forums/v6/4...-injector.html
https://www.thirdgen.org/forums/tbi/...roblem-no.html
Old Sep 1, 2013 | 07:56 PM
PaulD's Avatar
Car: 93 9C1 Caprice
Engine: 5.7
Axle/Gears: 3:42
Re: Yea, another "won't start" thread-update
I had the car towed home last weekend and I went to start diagnosing the situation yesterday. Thing started right up. Now I'm nervous about driving it again unless I can figure why it 'no started' before.
Several hours had passed from the time I turned the car off until I tried to start it so high temp was not a factor.
Anybody got anything? Please?
Hotrodboba400
Dec 10, 2019 07:07 PM
Linson
Sep 21, 2015 01:08 PM
Fronzizzle
Sep 8, 2015 12:10 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
