clicking sound from engine, help!
Old Aug 25, 2013 | 05:57 PM
janson33's Avatar
Car: 1988 pontiac firebird 2.8 v6 base
Engine: 2.8 v6 173
Transmission: automatic
Axle/Gears: stock
I was driving on the highway about 3 weeks ago really hard, then got off and heard a minor clicking sound. About a week later, did the same thing and it got a bit louder. Did it again today and its fairly loud now. Its coming from the driver side as far as I can tell. It MAY be the powersteering? No idea though :/ help!!
I drive it everyday but it only happens when I go on the highway
Old Aug 25, 2013 | 08:26 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: clicking sound from engine, help!
Check for exhaust leak(s).
Old Aug 25, 2013 | 08:34 PM
Shep5B's Avatar
Car: 1985 IROC-Z H.O. 4bbl
Engine: L69 Small-Block, 305
Transmission: Borg-Warner T5
You sure it aint one of your valves clacking. Mabye one of them is out of adjustment. Listen closely by the valve covers and pop the throttle a little bit and see what u got
Old Aug 25, 2013 | 10:31 PM
janson33's Avatar
Engine: 2.8 v6 173
Axle/Gears: stock
Got it! yes u were right, it was a leak. 3 of the bolts were loose. 1 was almost off, and 1 alrrady fell off. I have the pacesetter headers and never remembered to re-tighten them. Thx!
Old Aug 25, 2013 | 10:41 PM
Car: '87 Camaro
Glad it wasnt a lifter or valve issue!!
Now that you found the leak(s), make sure the gasket(s) are good & not torn // burnt // brittle.
Motor on in happiness...
Jae992
Aug 27, 2015 09:07 AM
B_Dubya
Aug 26, 2015 05:09 PM
db057
Aug 22, 2015 08:17 PM
midias
Aug 22, 2015 01:42 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
