1988 I-roc l98 cranks too long
Old Aug 28, 2013 | 08:39 AM
monkoskimike's Avatar
Car: 1988 I-roc
Engine: 5.7
Transmission: 700-r4
Axle/Gears: 3.73 posi
Ok so this is my first post but I have been reading on here a ton! This site had helped me alot. But I have been searching and trying and cannot figure out whats going on. Ok my car is my daily driver. It is 1988 l98 w/700r4 . Tpi. Ever since I got it over a year ago it always cranks too long before starting.... once its on it runns like a tank.any sugg3stions??
Old Aug 28, 2013 | 11:29 AM
Car: 1988 I-roc
Engine: 5.7
Re: 1988 I-roc l98 cranks too long
Tge fuel pump relay is good. The fuel pump primes when I turn the key. 12.75 volts @the relay. Oh and also it starts quick as a rabbit under 32 degrees?!?? Help
Old Aug 28, 2013 | 11:29 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Need to check the actual fuel pressure with a gauge.
The pump may be doing the prime OK but if the one way valve or fuel regulator are leaking then the pressure will drop straight away
as soon as the prime stops
Will not have any pressure holding in the rails to squirt fuel through the injectors when cranking over until the pump runs again.
Quick check is to bypass / hotwire the pump relay so the pump runs fulltime to hold the rail pressure and see if if starts faster.
If it doesn't then you know the fuel delivery / pump is not causing your problem
Don't forget to put the relay back to stock after testing
Old Aug 29, 2013 | 08:43 AM
Car: 1988 I-roc
Engine: 5.7
Thanks vet will try it later today
lt500r55
Sep 1, 2021 01:30 PM
gixxer92
Sep 1, 2015 04:32 PM
stalkier
Aug 21, 2015 01:54 AM
TheExaminer
Aug 19, 2015 10:07 PM
Winchester1094
Aug 18, 2015 10:23 AM
