building for torque
Old Aug 30, 2013 | 05:47 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
building for torque
so, I have a 89 305 roller block that im wanting to build for a project, and I want as much torque as I can sanely get out of it and it live. I have a MAF style TPI that I want to run.i have a set of "416s" that I want to port.id like to have forged flat tops too BUT my question is what would be the best cam for high torque production?? im gonna balance it maybe but ill have a 5000 rpm limit anyway. will a forged 350 crank fit??
Old Aug 30, 2013 | 09:06 PM
bwiencek's Avatar
Car: 1984 TA - 17k orig miles
Engine: 355
Axle/Gears: 3.44 Dana 44 performance rear
Re: building for torque
Build as much compression as you can, use as long a rod as you can, as flat of a piston as you can, as much head flow as you can get with a small runner and cam it for the lower RPM range and if you're really wanting to go for it - install a 3.75" stroke crank and gain about 20 CI of displacement and a long stroke/small bore will generally make a little more torque.
Old Aug 30, 2013 | 11:07 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
350 crank is the same as a 30Y crank but is balanced differently.
Old Aug 31, 2013 | 08:11 AM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Build for dynamic compression, not for 12:1 static compression. And stock rods will be fine. HR cams allow short duration with high lift, which does great things for torque. Adding 1.6:1 roller rockers will also do great things for cylinder filling without adding duration.
But if you build for power, you can get the torque back with axle ratio and torque converter, if automatic.
Either way, I'd go with the TFS 175 heads, and a shelf cam doesn't exist for how I'd do it. The XFI 254 has too much exhaust duration and too wide of a lobe separation, for low-RPM torque. Late exhaust openings really help low-end. But having overlap at 0.050" hurts low-end, so be careful.gl
Old Sep 2, 2013 | 10:18 AM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Get a 350 block.
You WILL make MORE torque & HP for less money
Good Luck !
Old Sep 2, 2013 | 10:36 AM
grumpyvette's Avatar
torque is the result of three major factors
displacement, cylinder pressure and volumetric efficiency, a TPI intake is designed to maximize efficiency in the 2500rpm-4000rpm power band (depends on cam timing heads,,displacement etc.)
the suggestion to buy a 350-406 short block, build it with a 9.5:1 compression ratio, and match it to a set of TRICK FLOW 175CC heads, so you can use that TPI intake with a cam similar to this, with 1.6:1 ratio rockers on that TPI will produce decent mid range torque, you might want to think of it this way, if a sbc engine makes 1.2 foot lbs of torque per cubic inch of displacement a 307 would produce about 368 ft lbs of torque, but a 383 would produce 460 ft lbs
http://www.cranecams.com/product/car...detail&p=23941
http://forum.grumpysperformance.com/...umetric#p35188
http://forum.grumpysperformance.com/...php?f=52&t=401
Old Sep 5, 2013 | 01:31 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Then you can figure out how you're going to plant that to the ground.
That's also a fun part.
I re-built a 10 bolt but I doubt that will work for you.
seiplentz
Aug 19, 2019 06:02 PM
Jorlain
Oct 8, 2015 01:57 AM
R13_Braz
Sep 18, 2015 05:00 PM
89newfun
Sep 16, 2015 09:28 AM
Ragtop Man
Sep 12, 2015 12:23 AM
