92 Camaro Won't Start
Old Sep 6, 2013 | 05:39 PM
north_oakland's Avatar
Car: 1989 Camaro
Engine: 2.8L
I have a 92 camaro RS 305 TBI and the car was running fine until the other day when it randomly would not start. The engine is cranking, but will not fire. I took the ICM to autozone to test and they said that it was good, so then I grabbed a spare ignition coil that I had and plugged it in and the car fired up no problem. I then went to autozone and bought a new one, I put it in the car and the car ran fine. I took the car for a short drive around the neighborhood and then parked it.
I went out this morning on my way to work and the car would not fire again. I switched batteries with my other camaro to see if my battery was bad and the car still would not start. I switched the ignition coil again and still nothing.
I am not sure where to go from here.
The first time the car would not fire I noticed that there was no spark and I did not see fuel coming out of the 2 injectors while trying to start. I am waiting for another person to come over so they can crank the car while I check for spark and fuel. I will post what I come up with.
Any help would be much appreciated.
Old Sep 6, 2013 | 06:43 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 92 Camaro Won't Start
Originally Posted by north_oakland
The first time the car would not fire there was no spark and I did not see fuel coming out of the 2 injectors
Until you identify which it is, a bit hard to talk your through the diagnostics
While you are waiting , you might read this on how to identify a no spark problem . 6 Pages
http://easyautodiagnostics.com/gm_ic...n_module_1.php
or the basis of fuel supply testing
http://troubleshootmyvehicle.com/gm/...a-no-start-2#2
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
