tpi idle hesitates, almost like wanting to die
Old Sep 6, 2013 | 09:25 PM
johndinu's Avatar
Car: '89 GTA 350 hardtop
car is stock. in the morning when cold it idles ok, but when at operating temperature idle is uneven and wants to die.
another issue although I was able to scan once in the past lately I can't anymore. I was looking for live data.
I may have a vacuum leak or leaky or partially clogged injectors. how do you check for vacuum leak? do you need to block some of the plenum ports?
checked spark and seems to have at all 8 cylinders. I'll change the spark plugs just in case
thanks for any hint
Andrew6.688
Dec 13, 2015 10:59 AM
Wade787b
Sep 29, 2015 01:15 PM
Sanjay
Aug 12, 2015 03:41 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
