No oil pressure, strange knock, please help
Old Sep 9, 2013 | 08:16 PM
TheBallPlayer's Avatar
Car: 1990 Camaro RS
Engine: 5.0 TBI Edelbrock Intake
Axle/Gears: 3.73 Posi
I was driving today and the engine started having no power and I saw the oil pressure gauge drop.. Now the engine is making a slight knock.. What should I do or check?
Old Sep 9, 2013 | 08:40 PM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
Re: No oil pressure, strange knock, please help
Drain oil look for sparkly oil, pull oil filter cut it open and look for more sparkles, sounds like spun bearing.
Old Sep 9, 2013 | 09:19 PM
Car: 1990 Camaro RS
If the oil is sparkly, and it is in fact a spun bearing, what should I do? Besides for changing the oil obviously..
Old Sep 9, 2013 | 10:03 PM
FtrSpeedy's Avatar
Axle/Gears: na/2.73
Stop driving it.
Old Sep 10, 2013 | 02:10 AM
3rdgenowner's Avatar
Car: 89 camaro rs
Engine: 350 tbi
Lol, yeah whatever you do...get the thing towed up to the shop and get that fixed, don't even start it.
Old Sep 10, 2013 | 07:41 PM
RyanJB's Avatar
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
If the bearing spun you're probably going to need a new crank or have your stock crank machined. You'll also need all new bearings. It certainly sounds like you spun a bearing, hope you didn't drive it to far...
89GTAOz
May 16, 2020 09:31 AM
Prodigious
Oct 4, 2015 11:20 PM
CamaroGuy350
Aug 30, 2015 02:56 PM
db057
Aug 22, 2015 08:17 PM
355sbcTPI
Aug 19, 2015 04:38 PM
