Problem with sump gasket seating properly
Old Sep 10, 2013 | 12:19 AM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
Hi,
I have a 1988 IROC with the factory L98 350 engine and T700.
When I bought the car the sump was damaged and had a patched hole so I bought an after market chrome sum and a new sump gasket.
I replace the sump when I replaced the engine mounts, by lifting the engine and squeezing the sump in on an angle.
However, I have a problem where the rubber gasket does not appear to seat properly at the rear of the engine around the curved part there the main bearings and rear of the crankshaft would be.
I've tried it a dozen times, but when tightened the sump gasket seems to keep getting pushed out in the middle. The front seems fine/
Pictures attached.
Is this normal or am I missing something?
Attached Thumbnails Problem with sump gasket seating properly-img_1220.jpg   Problem with sump gasket seating properly-img_1222.jpg
Old Sep 10, 2013 | 04:44 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: Problem with sump gasket seating properly
no, that's not normal, and yes, it will probably leak...
how are you putting it together?
you should be using the nifty little plastic guides that come with the gasket that screw in the threaded holes in the block to hold the gasket in place, then you put the pan up and try your hardest to tighten it down evenly..
Old Sep 10, 2013 | 07:01 AM
peterc005's Avatar
Transmission: T700
Thanks for the reply.
Everything lines up ok, including the plastic guides.
It's fine when the sump bolts are lightly tightened, but the gasket pops out the rear when I tighten the bolts up more firmly.
It's a 1988 L98, so should have a single-piece rear main seal, but I'm starting to wonder if the two-piece rear main seal if different and whether I've got the correct gasket ?
Old Sep 10, 2013 | 01:26 PM
Hello, Michael's Avatar
Car: 1987 Pontiac Firebird Trans Am WS6
Engine: SBC 350
Axle/Gears: 3.70:1 BW M78 9-Bolt Posi
Are you using silicone on the rubber pieces? If you are, don't. It will cause the rubber gasket to smush out, and it will leak.
Old Sep 10, 2013 | 02:17 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
looks like the wrong pan, the gasket will be a one piece and the lip on the pan will be flush with the rear man in seal adapter
Old Sep 10, 2013 | 07:15 PM
peterc005's Avatar
Transmission: T700
Thanks for the replies.
It's a single piece rubberised gasket. It cost more than the sump and appears to be good quality.
I didn't use any sealer on the gasket.
@Tuned Performance - good point, it never occurred to me that there may be different sump for the one or two piece rear mains.
I thought the rear of the sump lined up pretty well with the matching surface on the engine, but maybe the one and two piece rear main have a different diameter?
Old Sep 10, 2013 | 08:01 PM
Engine: Lb9
Transmission: M20
There is a right hand and left hand dip stick notch and one piece and two piece rear main seals. One two piece rear mains there are two different size front gasket thicknesses.
Old Sep 11, 2013 | 03:12 AM
peterc005's Avatar
Transmission: T700
The dipstick area matched up on the sump and gasket ok.
I'm thinking that either the gasket or sump was the wrong part, although my recollection is that the gasket mated against the block pretty neatly.
I was going to replace the damaged K-Member anyway and guess I'll have to remove the sump again to check this.
Might take the opportunity to replace the oil pump at the same time.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
