RPM stumble upwards, light backfire upon acceleration
Old Sep 13, 2013 | 02:04 PM
JesseShredd's Avatar
Car: 1992 Camaro RS
Engine: 1978 L82 355
Hey guys,
I have been troubleshooting this issue for awhile now. Upon acceleration and more noticeably hard acceleration, my engine stumbles as what seems to be a misfire but the rpms climb 200-300 instead of dropping. It happens very randomly. I did replace my wires, plugs, and distributor cap which solved the symptoms for awhile..but you know how karma comes back 'atcha!
A few things that I should mention to consider being related to the culprit are that my y pipe is dented from hitting a rock in a gravel lot, but not horrible. Maybe this is cause engine to run slightly rich? Also that I had to replace my floats in my carburetor a few months back. I did adjust them to factory specs but could be slightly off cause the bowls to flood ever so slightly which I could see making the plugs fire erratically. I also have no ECU/ECM, so sensors are not to be considered.
I'm really not to sure where to take it from here. Any suggestions would be great.
-Jesse
Old Sep 13, 2013 | 04:22 PM
maxjivi05's Avatar
Re: RPM stumble upwards, light backfire upon acceleration
Timing? What kind of distributor are you using?
Old Sep 13, 2013 | 04:44 PM
Car: 1992 Camaro RS
Not sure at the moment where the timing is set, but I have retarded it a bit from 12* which has helped slightly. Hei distributor with msd cap and rotor.
Old Sep 13, 2013 | 05:35 PM
maxjivi05's Avatar
I had the same issue and has taken me a week to get it right had to clean out the Carb even though it was new and set initial timing around 10* total should be around 36* but I was using 12* and it had a slight hesitantation and now it grabs and goes. So double check timing you may have to get a kit with weights and springs so the curve is what it needs to be for your engine.
Old Sep 14, 2013 | 09:20 AM
Car: 1992 Camaro RS
I cleaned carb, reset floats, no difference. Changed a plug wire, ran great for a one way trip, has started acting up again. Really present when warmed completely up. I'm stumped and really irritated with all the never ending ignition issues...
Old Sep 14, 2013 | 11:46 AM
Jonesyfxr's Avatar
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
Plug wire melted on exhaust manifold?
Old Sep 14, 2013 | 11:48 AM
Car: 1992 Camaro RS
Na, they all are looking fresh out of the box. I've been very careful about how I routed them around my headers to prevent this **** from happening again.
theshackle
Sep 17, 2020 08:26 AM
BewleyBizzIROC
Sep 7, 2015 08:05 PM
dyeager535
Aug 28, 2015 08:10 AM
wayshegoes
Aug 17, 2015 12:00 PM
Omega
Aug 10, 2015 12:46 PM
