WOT ?
Old Oct 3, 2013 | 12:27 PM
Americanmouse's Avatar
Car: 1988 IROC-Z28
Engine: L98(383tpi) modified
Transmission: 700R4 rebuilt
Axle/Gears: 3:73 10bolt rebuilt
WOT ?
Hey guys,
not sure if this is a ignition problem or trans. At wot around 6 grand in any gear like 1-2. It's trying to shift into the next gear and takes a few seconds to do so. The trans is a rebuilt 700r4 with a 2800 stall my ignition is MSD.
Old Oct 3, 2013 | 07:28 PM
JaBoT's Avatar
Re: WOT ?
probably the trans. Check the fluid level
Are you manually shifting it at 6k and it takes long to shift?
Old Oct 3, 2013 | 07:46 PM
Car: 1988 IROC-Z28
Re: WOT ?
I did check the fluid and its topped off, also noticed tiny bubbles on the dip stick not sure that's a problem? And I forgot to mention this happens at both manual shifting and leaving it in over-drive. If I drive normally it does not happen.
Old Oct 3, 2013 | 07:56 PM
JaBoT's Avatar
Re: WOT ?
if the tv cable is adjusted right then the trans is probably going?
Old Oct 4, 2013 | 12:31 PM
Car: 1988 IROC-Z28
Re: WOT ?
I'll re check the detent cable, but the trans probley has only 500 miles or so on it. And I actually bought the a rebuilt kit several years ago from Dana and had a trans shop rebuild it for me.
junior419
Apr 7, 2025 11:35 AM
Pac J
May 17, 2020 10:44 AM
86White_T/A305
Mar 6, 2016 01:48 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Damon
Sep 26, 2015 04:29 PM
