please help wont start
Old Oct 18, 2013 | 07:37 AM
lazey8's Avatar
Car: 1989 Trans am
Engine: LB9
Transmission: auto
Axle/Gears: 2.75
my 305 tpi is not starting I replaced the injectors and the fuel pressure is good. I checked the spark plugs and they were black so I changed them and sprayed a little starter fluid in the throttle body the car ran for a few seconds and quit I pulled the spark plugs again and the new spark plugs turned black after a few seconds. what in the world is going on I have fuel and spark could my fuel be bad? the car has had the same gas for I think a month now. any help would be greatly appreciated because Im at a lost.
Old Oct 18, 2013 | 02:29 PM
mcquigg's Avatar
Car: 85 T/A
Axle/Gears: BW Limited Slip 3.27 w/disc brakes
Re: please help wont start
Have you checked the injector fuses, check your ECM, it may not be triggering the injectors.
Old Oct 18, 2013 | 05:14 PM
lazey8's Avatar
Car: 1989 Trans am
Engine: LB9
Transmission: auto
Axle/Gears: 2.75
where are the injector fuses? i will check thar buti think they are working my spark plugs are black
Old Oct 18, 2013 | 06:04 PM
mcquigg's Avatar
Car: 85 T/A
The fuses are in the fuse box, there should be two of them. You said you used starting fluid, that may be what is leaving the carbon deposits on the plugs. If its firing with starting fluid then you need to look at the fuel delivery. Injector fuses shouldn't be blown unless there is a short somewhere but you want to check everything. If the wiring and everything checks out you can get a tester to put inline with one of the injector plugs to verify or just replace the ecm and don't worry about the tester.
Old Oct 18, 2013 | 06:31 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by lazey8
I replaced the injectors .
Why?
the new spark plugs turned black after a few seconds. what in the world is going on I have fuel and spark .
Black generally indicates too much gas in the cylinder or not enough spark ( weak ) to burn the fuel properly,
But given your engine is not firing up then that color would not unusual.
If they are black after the engine has run and warmed up then you have a problem
Old Oct 26, 2013 | 05:49 PM
lazey8's Avatar
Car: 1989 Trans am
Engine: LB9
Transmission: auto
Axle/Gears: 2.75
Originally Posted by vetteoz
Why?
i replaced the injectors because i thought they were leaking, be fore there were only 2 spark plugs coming out black but now all 8 are black, the car was running when only 2 were black
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
