My car wont start
Old Oct 20, 2013 | 07:41 PM
skylineR32's Avatar
Car: 89 Formula 350
Engine: 406 HSR
My car wont start
I am having trouble trying to figure out what my problem is.
The car is a 89 formula with a 406 small block with long tubes and a mini starter.
Earlier today I put a new stereo in and when I went to start my car it everything turned on inside the car but it wouldn't even attempt to turn over. I have had problems in the past with the starter. I've never had it where the starter wouldn't turn over. Does anyone have any other suggestions on what it could be? or would I be better off trying the starter first?
Thanks!
Old Oct 20, 2013 | 09:13 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: My car wont start
Originally Posted by skylineR32
My car wont start
ESP don't work well on the web ,a lot more info would be helpful
What tests have you one?
Is the battery fully charged? (like checked with a meter )
Do the dash lights come on with the Ign?
Do the headlights work?
Do you get any noise at all when trying to start , clicking , etc ?
Are the battery terminals clean and the cable connections tight? ( both ends )
And they would be ......................?
Did you fix them .........................?
Old Oct 20, 2013 | 10:14 PM
skylineR32's Avatar
Car: 89 Formula 350
Engine: 406 HSR
The battery is fully charged, the radio comes on the headlights work everything else works it just wont turn over. The starter doesn't make any noise.
The battery terminal ends are clean and tight on both ends.
Its kind of hard to describe the problems I had before but sometimes it would make a grinding noise, but if I would wait a couple of seconds and try it again and it would always start. We replaced the starter and never had that problem again.
Hopefully this was enough info.
Let me know if you need any more info.
Thanks!
Old Oct 20, 2013 | 10:56 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Park brake on , out of gear
At the starter solenoid , jump the small terminal ( purple wire ) to the big terminal from the battery and see if it cranks.
IF it doesn't then the starter is your problem
If it does , then you need to check the wiring from the Ign switch to the starter
Typical starter circuit.
http://92b4crs.tripod.com/86wiring/dia-pics/30-4.jpg
You don't state in your profile what trans you have ?
You should have a NSS on the shifter with a auto and a safety switch on the clutch pedal with a stick.
Either of those could be faulty cutting power to the starter
Old Oct 20, 2013 | 11:26 PM
ImBrandon's Avatar
Car: 1991 Pontiac Trans Am
Axle/Gears: 3:42
Does your car have vats?
Old Oct 21, 2013 | 06:20 PM
vdoggie's Avatar
Car: 1991 Z28
Engine: 350 tpi
Transmission: auto/stock
Axle/Gears: stock
since he was f'ing with wires installing a new stereo.. how much you want to bet it has to do with that? I will put up my pink slip against yours.. let's do this!
Old Oct 22, 2013 | 11:33 PM
pete0013's Avatar
Car: 86 iroc
Engine: 383 ci
Transmission: 700r4 Kevlar kit, non-lockup
Axle/Gears: 3.42 posi
While messing with the wires he could have cut/broke connection with the park/neutral safety switch. Just a thought.
Old Oct 23, 2013 | 07:24 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Yes the Park Nuetral safety switch wire runs right through that area.
Old Oct 24, 2013 | 09:38 AM
EvelBist's Avatar
Car: 89 Black GTA
Engine: 'close to' stock 5.7 but trending>>
Transmission: 700
VATS immediately comes to mind. Theres two small-gauge orange wires leaving the steering column down by the ignition switch/harmonica connector. Check them and their small white connector!
Old Oct 24, 2013 | 11:55 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Until the OP comes back and says exactly what he has ,
everything is pure speculation
Old Oct 25, 2013 | 07:23 AM
vdoggie's Avatar
Car: 1991 Z28
Engine: 350 tpi
Axle/Gears: stock
true.. but it's more than likely he cut or accidentally yanked on some wire(s) etc.. hopefully he can track down what happened rather easily.. especially if it's his DD.. that feeling is not good.. thank god I have five cars now.. always a spare on hand.. LOL
Old Oct 25, 2013 | 07:49 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Like I said
Speculation ;a waste of bandwidth without the OP's input
in any case ,a thinking person having problems after playing around with something would go back and check their work instead of asking online for people to guess at what "may" be wrong
Only they know what they did or can see under their dash, as I stated 1st up ESP don't work well over the net
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
