Mallory Hyfire HEI replacement - no start?
Old Oct 22, 2013 | 10:59 AM
thafaz's Avatar
Car: 86 IROC
Engine: 355
Transmission: WC 5spd
Axle/Gears: 3.24
Gents,
I bought one of these units a couple of years ago....finally got around to installing it.
Pulled the cap and rotor, removed the 4 pin module and condensor, installed the Mallory unit, attached the pickup wires, attached the 3 wire connector the the distributor, set the switches (all off....8 cyl, 5k rev limit) reinstalled the rotor and cap....simple enough.
However, the car would no longer start....no cough, no attempt...nothing.
I checked the wiring...no issues.
Replaced my original HEI unit....started first crank.
Any ideas?
Thanks,
FH
Old Oct 23, 2013 | 08:36 PM
mcquigg's Avatar
Car: 85 T/A
Axle/Gears: BW Limited Slip 3.27 w/disc brakes
Re: Mallory Hyfire HEI replacement - no start?
The module is probably bad.
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
justin57
Aug 20, 2015 07:05 PM
midias
Aug 15, 2015 05:07 PM
mizz0313
Aug 12, 2015 06:45 AM
