Gen III requires less timing than Gen I ?
Old Oct 24, 2013 | 10:41 PM
Cosmik Debris's Avatar
It seems that many LS1 cars have maximum timing of around 28 degrees at full throttle, most Gen I engines seem to like around 34 - 36. Is this because EFI does a better job at atomising the fuel or is there something about Gen III that allows less timing?
Old Oct 25, 2013 | 02:34 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Gen III requires less timing than Gen I ?
L98's are Gen I with injection
I suspect it is the whole package given the only thing in common with a Gen I the badge on the valve cover.
The head design in itself flows exceptionally
Old Oct 25, 2013 | 07:55 AM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
it's mostly due to the cylinder head design.
the LS heads (especially the cathedral port heads) flow some pretty impressive #s and also have improved combustion chamber design over the
Gen I heads. The result is less ignition timing.
Old Oct 25, 2013 | 08:17 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
The chamber and head design is more efficient at cylinder fill and burn. Better the head usually less timing needed. Also most ls guys run pretty high dynamic comp so they wont take much timing to begin with on pump gas
That being said i have seen some high dynamic comp sbc's with fast burn chambers only need 28-30 deg wot
eightsixseven
Dec 16, 2024 01:50 PM
midge54
Dec 27, 2019 04:14 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
ezobens
Aug 19, 2015 10:29 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
