Emission system missing parts?? what is missing?!
Old Oct 26, 2013 | 11:01 PM
Malicious3rdgen's Avatar
Car: 1998 Camaro rs
Engine: V8 350 5.7L TBI
Transmission: Automatic
I have a 1989 Camaro RS with a V8 350 LO3, and I'm living in California. I'm having a problem trying to find out what needs to go where on the emission system on my car. The diagrams, I seen aot are not helping me to find out what is the piece or components. If anyone can show me a pic(s) of what it is and where it goes. I'll be grateful. Name:  1989camaroRSv8350LO3butwhatismissinghere2_zpsa7d04b51.jpg
Size:  58.1 KBName:  1989camaroRSv8350LO3butwhatismissinghere3_zpsdec433cb.jpg
Size:  73.6 KBName:  1989camaroRSv8350LO3_zps520fe3bd.jpg
Old Oct 26, 2013 | 11:20 PM
IrocRoadRacer's Avatar
Car: 1989 Camaro Iroc Z
Axle/Gears: 9 Bolt Borg Warner/ 2.77 gear
Re: Emission system missing parts?? what is missing?!
Looks like the coolant hose that hooks up to the throttle body is missing. The two hoses hooked up to the valve go to the heater core. You probably never use the heat in California, so you may have never known the heat isn't working.
Old Oct 26, 2013 | 11:46 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
The item you show on the manifold in the 2nd pic is only a bolt hole for the compressor brace
Old Oct 27, 2013 | 12:53 AM
Car: 1998 Camaro rs
Thanks, Its more less than a puzzle now to fig what is in the other pic where a hose or something fits there.
Old Oct 27, 2013 | 01:00 AM
Guest
Guest
Posts: n/a
The L03 is a 305, just to avoid any confusion. You are missing the throttle body coolant hose. You should see a large nipple like port coming off of the passenger side of the throttle body, angle ever so slightly downwards. The hole you indicate in front of the thermostat housing, nothing is meant to go there. It's a bolt hole and on my L98 I have the same one in the same position, empty.
Old Oct 27, 2013 | 01:39 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
https://www.thirdgen.org/forums/post...356-post3.html
http://ls1tech.com/forums/15610589-post1.html
Old Oct 27, 2013 | 01:15 PM
Guest
Guest
Posts: n/a
L03 is a 305, to avoid any confusion.
Old Oct 27, 2013 | 06:33 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
So you are missing parts.
This pic clearly show the back brace for the A/c compressor going there
Old Oct 28, 2013 | 01:43 AM
Car: 1998 Camaro rs
Thank you for all this advice and pics to what is missing, It's great to have a camaro community to help when needed.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
sreZ28
Aug 14, 2015 07:48 PM
1nastygta
Aug 8, 2015 07:38 PM
