power steering bracket modifiaction help
Old Nov 3, 2013 | 10:42 PM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
ive got a 91 305 tpi converted from a tbi. i traded out the serpentine set up for an alternator and power steering bracket set up. i didn't have a/c or smog and wanted to clean up the engine. i switched out the reverse water pump for one from an 86 and used the alternator. my problem is with the power steering mount.
i tried to use the power steering unit from the 91 but it will not line up with the install kit. the same goes for the the 86 power steering pump. either the unit is not clocked in the right direction or the bolt on the back will not line up to the new bracket. i could use the original brackets but don't want to if i can avoid it. the kit i got says it will work on power steering pumps from 69 to 73 and other sbc using long water pump.
will a pump from 69-73 work on my car? i know ill have to get the correct keyway pulley.
Old Nov 4, 2013 | 03:24 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: power steering bracket modifiaction help
I don't know about year-to-year fit compatibility of GM PS pumps. Someone else probably has better info than I do. But IIRC, two other issues with GM PS pumps are:
1. Getting a pulley that will work with the pump shaft and belt arrangement you have (some shafts are keyed and some are press fit).
2. Another thing is the fittings. The early pumps are SAE and the later ones are metric. Your '91 should have a steering box with metric fittings. I don't think they make an off-the-shelf pressure hose with one end metric and the other SAE. Maybe an adapter is available or you can have a custom hose made.
Old Nov 6, 2013 | 09:22 PM
tonys91rs's Avatar
Car: 91 Camaro RS
I got it worked out. I relocated the rear bolt from top to bottom.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
Genopsyde
Nov 11, 2015 10:46 PM
