dirt in lifter valley..HELP~
Old Nov 5, 2013 | 11:46 PM
Slow87's Avatar
Car: 87 Camaro Lt
Axle/Gears: 4th gen 3:42, posi, disc
I have a 350 on a engine stand with no heads/intake/oil pan. A bunch of dirt and crap is in the lifter valley and the cylinder holes. Without taking it apart is there a way I can clean it all out? I was thinking I could spray a lube through everything but that sounded stupid in my head.
Old Nov 6, 2013 | 01:05 AM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: dirt in lifter valley..HELP~
Any idea how it got there? U pull it motor, or a short block stored uncovered for x amount of time?
What do the crank & rods look like?
You ** may ** be able to wipe it out with some oil soaked rags, & hope you got it all out. Its a gamble.
Are the lifters in?
How long has the motor been out of use?
Old Nov 6, 2013 | 07:19 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
I would start with the old shop vac and a little brush. Get all you can with the vac and then keep it running in the same area as you are brushing. An old paint brush will work good. Then you could use an oiled rag to get the remains, take your time.
Old Nov 6, 2013 | 01:34 PM
Car: '87 Camaro
Old Nov 6, 2013 | 02:01 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I know that cleanliness is next to godliness, and I am meticulous when I'm around an open engine, but to be perfectly honest, in my college days I helped buddies change intake manifolds on crusty old cars in parking lots, and we watched all kinds of crap fall into the motor when we pulled the dirty old intake off. We'd pick out what we could, then pour a little oil into the valley to wash it back into the pan, then be on our way. Those motors continued to live a happy life for many years thereafter.
The point I'm making here (yes, there was a point!) was that although you absolutely should follow the advice that others have given and get it as clean as possible, once you do that, don't freak out about it. I'd definitely want to get every last bit out of the cylinders if some is in there, because it can score your cylinder walls, but a little bit in the valley isn't really something that I'd get overly nervous about as long as you get as much as you can out, and then just pour some oil into the valley to help the rest drain into the pan, followed by an oil change.
Old Nov 6, 2013 | 07:15 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
With Jim
Grab a gallon of diesel and start pouring with a catch pan under it. Wipe the cyls down flip it over, ck. Youll be fine. Ive left wrenches bolts rags in the lifter valley and the motor lived just fine LOL
Old Nov 7, 2013 | 07:40 AM
bestracing's Avatar
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
That works good but if the material is like a wax then I would use a flat blade screw driver to scrape the material out first and then do what is described above.
Back in the mid 80's I helped a friend swap out a 2bbl manifold for a performer manifold and everywhere the oil would puddle he had a waxy material built up. They used Valvoline oil and changed it every 3-4K and the motor only had 40K on the odometer. It had to be scraped off
skinny z
Oct 5, 2015 06:23 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
84redta
Sep 19, 2015 09:58 AM
64Chief
Sep 12, 2015 08:05 AM
dimented24x7
Sep 6, 2015 03:51 PM
