Power estimate? Just curious
Old Nov 16, 2013 | 06:20 PM
  #51
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Sound better now?
Old Nov 16, 2013 | 08:14 PM
  #52
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Re: Power estimate? Just curious
Yep, sounds like a lopey cam.
Old Nov 17, 2013 | 04:43 PM
  #53
JaBoT's Avatar
Still doesn't sound right.
Old Nov 17, 2013 | 04:56 PM
  #54
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
I found my problem :/ I made another post about it
Old Nov 17, 2013 | 06:14 PM
  #55
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Originally Posted by InfernalVortex
1 hp per cubic inch is not easy to do. GM could never do it, that's for sure. We can do it if we sacrifice enough low end torque and put enough money into cylinder heads. Basically your cheapest way to get into the 350-400 range is to hope you have flat top pistons that arent .045 in the hole, and then to get some Vortec heads and switch to an XR276 roller cam. That will require machining the valve guide to get enough clearance for that lift. That cam is 224/230 @ .050 and should have a power band around 2000-5800 or so. It should get you between 350-380hp. A cheaper option is Vortec heads and an LT4 hotcam, that's about 325-350hp, again, roller cam. You have an early 80's block, so you're not going to be able to go roller cheap... The only way to hit 350+ hp on a 350 is good heads and a good cam. Doing it and keeping the street manners is easy if you can go roller cam. If you're limited to flat tappets, you're gonna have a rough time of it. Maybe something like an xe274, but that's pretty lumpy for a street cam although you have the gearing for it. An xe268 is a reasonable street cam and will get you 310-340hp on a 350 with decent heads.
Which would better suit me and what power can I expect between these two? I only ask because I have them lying around.
Cam 1
500/500 240/250 110 lsa
Cam 2
420/442 204/214 112 lsa
Old Nov 18, 2013 | 09:14 AM
  #56
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Anybody??
Old Nov 18, 2013 | 09:43 AM
  #57
JaBoT's Avatar
cam 1 is way to big. cam 2 is pretty small, but if i had to choose cams 2 because you have stock heads.
Old Nov 18, 2013 | 10:04 AM
  #58
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
This is just to get it running again, if you had to choose what cam would you pick aside from these two?
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
RedLeader289
Jan 22, 2016 03:05 PM
skip91
Sep 24, 2015 03:29 PM
bellez77
Sep 5, 2015 08:39 PM
sailtexas186548
Aug 24, 2015 10:11 PM
