Blue smoke
Old Nov 15, 2013 | 04:08 PM
pontiacdog's Avatar
Car: '86 Trans Am
Blue smoke
When I start my '86 trans am there's a thick cloud of blue smoke coming from the exhaust pipes.
Which seals / gaskets should I replace? The car has 105k miles on it.
Most of all I'd like to see pics of other people's projects of taking apart the TPI engine.
Old Nov 15, 2013 | 06:14 PM
Re: Blue smoke
That's typically the valve guide seals.
Not too tough really. Good opportunity to change out the valve springs and all their hardware as well; you might be surprised at what a difference that can make, especially at upper RPMs.
Old Nov 15, 2013 | 07:04 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: Blue smoke
on my 89 the drivers side wasn't too bad.the other side has tons of stuff in the way.
Old Nov 22, 2013 | 11:17 AM
pontiacdog's Avatar
Car: '86 Trans Am
Re: Blue smoke
Ok I ran into a problem.
How do I work my way to the valves without removing the a/c compressor?
It's under high pressure and thus it can't be removed, just got it recharged last summer.
I can't take it to ac shop because it's winter in Finland and the car is already in pieces in a rented garage.
Old Nov 22, 2013 | 11:22 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: Blue smoke
You should be able to unbolt the compressor and just lay it off to the side without undoing the A/C lines to it.
Old Nov 23, 2013 | 11:04 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Blue smoke
This.
Notice the compressor laying on the overflow tank.
Linson
Oct 24, 2025 02:00 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Lbibb
May 5, 2016 12:00 AM
gord327
Oct 3, 2015 01:25 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
