92 RS 5 speed no start
Old Nov 19, 2013 | 02:49 PM
TheBallPlayer's Avatar
Car: 1990 Camaro RS
Engine: 5.0 TBI Edelbrock Intake
Axle/Gears: 3.73 Posi
Hey guys i have a 92 RS 305 5 speed. When i bought the car it started up fine. As i drove it more and more it started having issues. A week ago the starter motor would turn(so would the engine) and ever since i put it in the garage the starter motor wont even turn. I havent touched it or done anything to it. I already tried jumping the starter enable relay and nothing happened. Can someone walk me through what i need to do here, what to test specifically? When i turn the key nothing happens, i can hear the fuel pump turn on and I CAN HEAR the starter enable relay click, thats it, and the bulb test. Thanks, i need all the help i can get
Old Nov 19, 2013 | 04:59 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 92 RS 5 speed no start
Is the battery FULLY charged , as in tested , not that you think it is good?
Are the connections on the 2 battery cables in good cond , clean and tight ( both batt and engine ends) ?
If so, run a wire from the solenoid terminal (purple wire ) on the starter and touch it on the Batt Pos + terminal.
If the engine cranks over , your problem is with the wiring from Ign switch to starter
Check the clutch safety switch is properly adjusted and working
If engine doesn't crank over ,you have a problem with the starter itself.Remove and have it tested
Old Nov 19, 2013 | 06:25 PM
Car: 1990 Camaro RS
I took a volt meter to the purple wire on the solenoid and it was reading 12.5 when the key was turned to the start position. So this means the solenoid must be bad, im gonna drop the starter and put a whole new one in. Ill let you know what happens after i put the new one in.
Old Nov 19, 2013 | 09:23 PM
MrPackstin's Avatar
Car: 1989 GTA
Engine: 5.7 w/Paxton
Sometimes you can tap the solenoid with a hammer and it will pass voltage to starter motor. Obviously, it will fail again. It will tell you if the solenoid is bad or not.
Old Nov 20, 2013 | 07:31 AM
Car: 1990 Camaro RS
The car cranks now, but its not firing up. Im trying to get a holdof a test light, i can smell fuel while its cranking, so im leaning towards a spark issue, or timing
Old Nov 20, 2013 | 01:36 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Do the tests
http://easyautodiagnostics.com/gm_ic...n_module_1.php
Orr89RocZ
Apr 25, 2016 08:28 AM
jbd1969
Aug 17, 2015 07:06 PM
perZ
Aug 15, 2015 01:17 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
86Base
Aug 8, 2015 01:34 PM
