Alternator Cable
Old Nov 21, 2013 | 06:48 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
Alternator Cable
I blew the inline fuse on the wire going from the stud on the back of my alternator to the stud bolted on the body next to the battery. I can't seem to find this wire at any parts stores. Does anyone have a part number or know where I can get one? Boneyard doesnt have any. Also what is this wire for? I'm assuming ground, but would like to know for sure.
Old Nov 22, 2013 | 07:34 PM
Damon's Avatar
Re: Alternator Cable
Picture would help. I don't recall GM ever grouding the alternator to the body of the car. Ever. Sounds like something added by a P.O. (and completely unnecessary if all the factory grounds are in place)
Old Nov 22, 2013 | 09:51 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Its definitely factory. I goes to a stud next to the battery along with multiple other cables. I'll try to get a picture tomorrow. It comes from the stud on the back of the alternator.
Old Nov 22, 2013 | 09:54 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
I guess thats actually the output to the battery?
Old Nov 23, 2013 | 05:33 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
To my knowledge the only fuse that should be by the battery is the fuse for a fuel pump of an efi car.
Old Nov 25, 2013 | 05:33 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Alternate Universe
Originally Posted by NagleMac
inline fuse……………I'm assuming ground………..Its definitely factory.
NEVER !
There are no fuses in the ground portion of your car.
You are either misinterpreting what you are seeing or it’s a PO mod as
Damon stated.
Also, there is no stock inline fuse for the alternator, however if you physically trace the wires it leads to one or more fuses depending on VIN but they are for different purposes.
Nope, not that either.
Anyway because you want to replace some wires you should try some aftermarket outlets such as
PainlessWiring
.com.
Happy Racing!
They Want To Put HOW MANY Cameras In My Car Next Year ? ! ? ! ? !
apie2546
Oct 16, 2016 02:24 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
