'88 TPI emissions correct removal
Old Nov 24, 2013 | 01:53 AM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
What i mean by "correct" is with the ECM continuing to do its job without Check Engine on...its a classic and registered in a Texas non-emissions county (so far). This what i'd like to do and will need TGO's members help. Serious replies are appreciated on this.
So i want to delete the air pump and replace it with the "delete" option pulley - remove the solenoids above the passenger side valve cover - all air tubes -remove the CAT - remove the EGR i hope? - I think i have to keep the o2 sensor right? AND then here's my REAL question.....The Engine light, What custom Mcal , Chip or remap will i need? Who can i get to do this for me? The car is near the end of a 4 year resto so i'm going to have this done right i hope. I'm just not hip on this CHIP remap stuff or i would do it myself. So i'm counting on someone's experienced history on this to help me in the right direction..Thanks again,
Old Nov 24, 2013 | 10:38 AM
87irocZ28Crush's Avatar
Car: 1987 Iroc Z28
Re: '88 TPI emissions correct removal
I had just gone through and did what your talking about. I removed everything but the o2. You are going to have to keep that. I believe it helps with fuel delivery. Look up tunedperformance on here. He did a great job at doing a custom chip for me. No check engine lights and a real nice idle after the new chip. You car will run without a custom chip not not well. He will also lower fan kick on temp and vats removal and any other upgrade that you have done.
Keith
Old Nov 25, 2013 | 09:05 AM
mjdavis68's Avatar
Keith
Alright i'll check into it now, thanks
Old Nov 26, 2013 | 04:18 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
https://www.thirdgen.org/forums/post...781-post4.html
I removed everything but the o2. I believe it helps with fuel delivery.
The O2 sensor is a essential part of the engine operation , without it the ECM has no idea how much fuel the engine needs
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
Sanjay
Aug 12, 2015 03:41 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
