heater wont blow hot
Old Dec 5, 2013 | 11:52 PM
likwidmetaldeth's Avatar
Car: 87 firebird
Engine: lg4
i have a lg4 87 firebird. this summer i had to replace the intake manifold and later i removed the ac compressor. could either of those affected the heater core? it wont blow hot air now unless the rpms get past 3k or so
Old Dec 6, 2013 | 08:37 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: heater wont blow hot
Did you put a thermostat back in when you put the water neck back on the front of the motor?
When your driving, what temp does the car get up to after the manifold swap? It's a common thing to miss when putting it all back together. Without the thermostat, the car won't get warm enough to run the heater generally unless your sitting for a long time or running the motor hard.
Old Dec 6, 2013 | 08:37 PM
Car: 87 firebird
Engine: lg4
it does have a thermostat. had a couple in there to make sure that wasnt the problem. manifold temp is 205-210
Old Dec 6, 2013 | 08:38 PM
Car: 87 firebird
Engine: lg4
ive also removed the smog pump and egr stuff. do any of these or the ac compressor supply vacuum to the heater core?
Old Dec 6, 2013 | 09:55 PM
manolis1969's Avatar
Car: klowny1969 <-youtube 4 3rd gen vids
Engine: subscribe to klowny1969 on youtube!
Transmission: subscribe to my channel on youtube
With the car fully hot and the heat all the way up..grab the two heater core hoses that go to ur heater core..if one is hot and the other cold..then ur heater core is clogged..
Checkout my videos below on how to replace a heater core..and please subscribe for free to my youtune channel..thanks
Old Dec 9, 2013 | 11:11 AM
Car: 87 firebird
Engine: lg4
thanks that appears to be the problem
Old Dec 9, 2013 | 11:17 AM
Car: 87 firebird
Engine: lg4
nice vids btw im gonna give it a shot in the next few days
Fanatic1074
Oct 2, 2015 03:47 PM
ironbmt
Sep 27, 2015 06:00 AM
