Sbc 383 1 lifter no oil
Happy Holidays and Thank you for any help anyone can provide!!
I have a 383 stoker, I've recently built. New Roller Cam and New Roller Lifters. After 300 miles i noticed on the passenger side lifter chatter. I started the engine with the valve covers off. And noticed all lifter were pumping oil except the 2nd lifter. All others were okay. Is it possible that this 1 lifter has failed?Purchased new from summit
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Re: Sbc 383 1 lifter no oil
also check rocker arm......have seen some that are blocked and dont allow oil flow
I will check the rocker and blow some compressed air through it. I wanted to cover basic before. I took the intake off to see what was going on. All of the lifter seems to be prime. 2nd Lifter that's not pumping is easily push down.
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
I thought this crap only happened to me, hate when brand new stuff fails, it can get you second guessing yourself. Let us know whats going on with this project.
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
What brand of lifters?
Did the block have machine work? Was it cleaned and washed throughly?
My thoughts are something may have gotten pumped into the lifter and has it plugged.
Try pulling the lifter and cleaning out.
Yes i did have the block machine. You have a point i didn't have rings at the time when it was machine. So i had to take it back to get the piston rings filed to the cylinders. May not have been clean properly second time. I believe i got them from summit. Oem type i know they was nothing expensive. I guess i better take the driver side off and make sure everything is okay there also. Oil pressure is 55 - 60 a idle.
Car: 1971 Camaro
Engine: 427
Gm lifter are pretty reliable.
Pull the lifter out and clean it. See it that cures it.
I'm speechless... I took the valve cover off on the driver side... 1 of the screw in studs were broken........... I've had them in a previous engine. For a few years before putting them in this engine... There cheap ones off ebay... Could this be the case or is it possible there is a underlying problem.. I took the carb off.. Raw gas was sitting underneath in the intake alot and the bottom of the Carb Flaps was wet as if it was leaking gas into the intake..I'm running Psi at 4.5...
Arp screw in studs? And where that stud is broken. The lifter is destroyed. The pushrod was just sitting there
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
Might want to pull the head and check out the underside and the pushrod hole. That's some crazy ****, similar to what happened to me. I had two valve springs break and a rocker stud pull, pulled the valve cover and just sat there confused as to why my new parts with <4000 on them broke like that.
I know the coil height is correct. I think it's the run out on the Screw in studs i have. I checked back with the eBay user i bought them from. He discontinue selling them. because of so many problems
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
