anyone ever use the SUMMIT brand 8' nodular balancer? what are these markings for?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: anyone ever use the SUMMIT brand 8' nodular balancer? what are these markings for
The marks are for timing. You can use a feedback timing light when referenced to the pointer zero to see the advance.
okay thanks, never used an aftermarket one before so the lines going from 0-60 threw me for a loop
it's done so you can actually read and curve the ignition without having the need of a dial back light. DO make sure your degree pointer matches the 0 (piston stop if not rebuilding engine) for accurate results
yea i dont have a fancy timing light, and iv redone the top and, but i didnt touch the crank rods or pistons only the oil pump in the bottom end
UltRoadWarrior9
Sep 2, 2015 08:24 PM
