is this a bad idea?
is this a bad idea?
would letting the sludge covered push rods, lifter retainers, rocker arms and little circle things in the rockers sit in a gallon of carburator parts cleaner over night be a bad idea? i wouldnt think it would hurt anything but i just wana make sure
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: is this a bad idea?
It won't hurt anything , assuming your saying the dog bones and have roller lifters. If they are slid get you will want to take apart all the lifters for cleaning and inspection.
Engine: Lb9
Transmission: M20
With the lifters, you might want to use pb blaster and soak them down with that before disassembly. It is designed as a great penetrator but works real well cutting grease and even carbon build up on pistons, in cylinder heads ect.
tuned im not disassembling the lifters, why would i do that, they came out of the engine they are going back into that only had 68k on it? the only sludge in the whole motor was inside the valve covers and lifter valley, the rest looks super clean, theres pics in my project thread i believe...
Engine: Carb'd LT1 w/ a Cam :)
Axle/Gears: Moser 9" w/ 3.75 gears
If theirs sludge in your lifter valley and all the associated valvetrain parts, then theres sludge IN your lifters, in your oil pan and on your rotating assembly too.
You dont HAVE to do anything, but if you care about the condition of the internals, you'll clean them.
iv never taken a lifter apart, how would i go about doing so? and when i had the pan and timing cover and chain ect all off to put a new oil pump in, eveything looked very very clean. tops of the pistons were even really clean, so were the heads
makes sense, im sorry i sound like an idiot but iv really never taken a lifter apart before, i usually buy new ones or just throw em back in, but with only 68k i want it to be right and last a long time... is it really necessary? whats the right way of doing so if i am going to take em apart and clean em?
diesel fuel is a great solvent!
just soak em in diesel? then back into the bucket of engine oil? without taking them apart?
why not let em soak in carb parts cleaner like the other parts?
Engine: Lb9
Transmission: M20
thats irrelavent tuned, maybe you should pay more attention, i ALREADY said they ARE and have been soaking in oil, which is all that link u posted states...... and mine are not NEW.
Engine: Lb9
Transmission: M20
It shows how to take apart the lifters, Depending the spring tension you may have to make a tool for reassembly. Your engine your problem if a lifter doesnt want to pump up or gets stuck in its bore from the coked up oil. You asked for advice advice was given. Not a chance I would take on a used engine. unless you like pulling the intake and re-lashing valves for the what if scenario.
Engine: Lb9
Transmission: M20
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Don't know you formed your opinion on this, Tuned Performance is one of the best advisors on this site. He's all give.
