Fuel Tank to Filter Line Replacement
Old Jan 1, 2014 | 03:38 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I am in the middle of installing new fuel lines on my car and currently ran into a problem. I need to change the rubber part of the line that is between the tank and the fuel filter. Nobody seems to make these for our cars. I found this section of line on summit racing. Would this work to put in its place? http://www.summitracing.com/parts/nex-14012/overview/
If so would I have to change over the fittings on my new lines to an fittings?
Old Jan 1, 2014 | 07:41 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: Fuel Tank to Filter Line Replacement
Yes, if it's long enough, with siganaw fuel line connectors, or-6 AN adapters like these.
TPI Fuel Adapters
Old Jan 2, 2014 | 05:53 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Would this adapter work to connect my hard line from the tank to the new AN line on the hose i'll be making? Thanks.
http://www.jegs.com/i/Aeroquip/023/F...49#moreDetails
Old Jan 9, 2014 | 01:17 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Yes if the hose has a female 6-AN connector.
Have you searched for less expensive connectors, they don't have be made from aluminum.
1992 Trans Am
May 10, 2023 07:19 PM
mustangman65_79
Apr 14, 2017 05:37 PM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
AkDrifted
Aug 17, 2015 07:45 PM
