Engine not idling good
Old Jan 10, 2014 | 01:48 PM
289coupe's Avatar
Car: 1990 Camaro
Transmission: 5 Speed
Ok so i have a 1990 camaro with a early or mid 80's carbed 350. I just replaced the throwout bearing, clutch master, slave cylinder, plug wires, and 2 of the fusible links by the starter. Took it for a drive yesterday and drove about 30 or 40 miles and it died, couldnt get it to start, seemed like no spark. Went back this morning with the car hauler to pick it up and get it home and it started right up but it doesnt idle well at all and its smoking a little. If you keep your foot on the gas at about 1500rpm it will run ok but anything below that it sounds horrible and will eventually die and is very hard to start again. Any help would be greatly appreciated!
Old Jan 11, 2014 | 10:16 AM
289coupe's Avatar
Car: 1990 Camaro
Re: Engine not idling good
I figured it out. Thanks for everyones help....
Old Jan 11, 2014 | 11:00 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
What was it?
Old Jan 14, 2014 | 09:16 PM
289coupe's Avatar
Car: 1990 Camaro
Power valve blew out in the carb
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
db057
Aug 22, 2015 08:17 PM
midias
Aug 22, 2015 01:42 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
