Junkyard heads
Old Jan 12, 2014 | 10:44 PM
DirtySpleen's Avatar
Car: 1991 Camaro RS
Engine: 5.0 L03
Axle/Gears: 3.43 Torsen 10 bolt
Junkyard heads
*Before I start, I KNOW that the L03 isn't worth its weight in scrap, so lets stay productive in the answers*
We all are aware that the poor airflow of the L03 is its major downfall. one major part of that, is the fact that the heads are about as effective as breathing through a straw. For the sake of curiosity, what are a few options for JUNKYARD AVAILABLE heads that could be found on engines of cars you may commonly come across that would free this up a bit? Everyone knows to just build a 350, but for those that currently can't, this could be an option, as at my local yard, heads are only $37.99 each. Are there any that would give any improvement, any higher rpm capabilities, anything? Thanks.
Old Jan 12, 2014 | 11:00 PM
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Re: Junkyard heads
Vortec 305 heads would probably be your best bet, out of a 96-98 pickup, I think they only came in the 1500s, and usually the 2wd ones I believe. Not sure what those heads would do to your compression ratio tho.
Old Jan 12, 2014 | 11:28 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Junkyard heads
if everything is still stock,the factory cam and exhaust system is a worse restriction than the stock"swirl port" heads-you can get well above factory horsepower rating and RPM limits before restriction of factory heads becomes a factor.
Old Jan 13, 2014 | 12:09 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Junkyard heads
Originally Posted by Formula 305
Vortec 305 heads would probably be your best bet,.
If they are " real " Vortec heads they require Vortec only intake which rather blows the budget idea
Old Jan 13, 2014 | 12:21 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: Junkyard heads
https://www.thirdgen.org/forums/tbi/...-headflow.html
BlueIroc-Z
Jun 9, 2019 03:22 AM
okfoz
Convertibles
83
Oct 29, 2018 11:18 PM
92projectcamaro
Jan 18, 2016 08:00 AM
z28guy134
Sep 1, 2015 11:50 PM
matthew911
Aug 12, 2015 09:38 AM
