ignition coil burning?? help
Old Jan 15, 2014 | 07:41 PM
topgun89's Avatar
My car recently started burning ignition coils, I tracked the problem down to a bad ground which I replaced. However after three weeks of driving the problem has comeback and the car has burned two more coils since. All the wires and grounds are testing positive/good so far. Has anyone ever experienced this problem ?? any help would be appreciated.
(my neighbor took a look at the car and told me that i might have to strip the paint of the ignition coil bracket. I painted it and the ground is directly under this bracket he believes that the paint is affecting the ground, "he stated the ground need to be on bare metal)
Also can anyone tell me what the part this is I am trying to replace it but have no luck finding it.
Attached Thumbnails ignition coil burning?? help-unnamed3.jpg   ignition coil burning?? help-unnamed22.jpg   ignition coil burning?? help-unnamed333.jpg
Old Jan 18, 2014 | 08:53 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: ignition coil burning?? help
the part appears to be the EGR vacuum solenoid.
on burning the ignition coil up, are you talking about burning it out electrically, or it actually burning up like it was on fire?
is this the divorced type coil that is mounted on the motor? if it is, then other than the wiring going to it, it doesn't need a ground.
the main 2 reasons for an ignition coil to die are 1, bad wires/cap/rotor/plugs, or 2, just a cheap or defective coil.
MM2Robinson
Oct 1, 2017 09:16 AM
BumpaD82
Feb 26, 2016 02:57 PM
85 Jimmy
Sep 30, 2015 07:56 AM
Jlanz55
Sep 6, 2015 03:05 PM
Jlanz55
Sep 6, 2015 02:35 PM
